What surface based software works best with Onshape?
burhopburhop Member Posts: 22 ✭✭
I want to create some surfaces that are beyond the capability of Onshape (so far :smile: ) but I still want to use Onshape for most of the mechanical CAD work.
Is anyone using any free or low cost software that can create Onshape (e.g Parasolid) compatible surfaces?  Yes, I know Rhino is great but I can't afford that as this is just a maker project.
Ultimately, I'd be doing a split face or replace face with the geometry in Onshape.
    What can you do in Blender? I think this free, uses open cascade. That all I know
  • clayton_ertleyclayton_ertley Member Posts: 58 ✭✭
    edited May 2015
    I will have second the Blender suggestion. It is in fact free and there is no fee to pay if you make money off of your designs. It is a VERY capable program though it has a learning cure and most function are accessed via keyboard shortcut. I have had much success in using blender.
    I think the question is this: does Blender (or some other free software) produce high quality surfaces in Parasolid format?
  • burhopburhop Member Posts: 22 ✭✭
    Yes.  I think you are right.  Has anyone imported Blender surfaces into OnShape?
  • michał_1michał_1 Member, Developers Posts: 215 ✭✭✭
    Problem with Blender is that it's no cad software by any meanings. You can work with nurbs surfaces but as a result you get a mesh only, like this one:
     I don't now way to get a nurbs from Blender.
    mesh.png 471.2K
    edited May 2015
    Recently came across this one, not sure if it will work for what you need, but looks interesting:
    http://cyborg3d.com/index.html
    That does look interesting.  Unfortunately, it is not released yet.  I did ask to join the beta.
  • kevin_quigleykevin_quigley Member Posts: 306 ✭✭✭
    edited May 2015
    Integrityware are the people behind Power Surfacing for SolidWorks, and a lot of add ons. No doubt they are talking to everyone, other than Autodesk!
