Sheet Metal Cut in Flat Pattern
kent_henderson
Member Posts: 70 PRO
https://cad.onshape.com/documents/6a4442aa4be150f4df289717/w/bc65d5e9efeea47402c31a16/e/95dd8a5c8b697a68adcc6b75
Take a look at the attached document. I have a series of 6 holes that when the extrude is unsupressed, the flat pattern breaks. These are cuts in the flat pattern. It seems if the edge of a flat pattern cut lands on the bend radius the flat pattern breaks. These holes are 0.425 Ø If I change to 0.25 or 1.00 everything is fine. Is this a bug?
If you cut half of the circle it will work, but once you add the other half the flat pattern goes away. This is the closest I could come.
https://cad.onshape.com/documents/ddb1b210c024bfc8fe278ee1/w/c5a2daf0b5e6e2c647a28514/e/646573c9e8d5f31cf41b3f92
This is the alternative I could come up with. Sorry for the crudeness, I was trying a lot of methods to get something to work.
https://cad.onshape.com/documents/d5476f02bf64b50d67af23d2/w/da85b5d3206eb5c10850721a/e/2c789c12124b03425edb2896
Twitter: @BryanLAGdesign
