Apple magic mouse compatibility
It would be great to make Onshape more Mac friendly (and not requiring a non Apple mouse with the 3rd wheel/button) if the panning function would work by using a combination of the right mouse button (now rotate) + holding down the spacebar. I think I've experienced this kind of behaviour in some other program - possibly in Adobe Illustrator to pan around the canvases.
    I thought we could pan using ctrl plus right mouse button? Have you looked into Better Touch Tool? You can add a middle mouse click action using the middle portion of the mouse as the virtual button.
    Brian
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,015 image
    @William_van_Beek Many of us use them here internally.  I am wondering if there is something you are missing.  Maybe enabling right click context?
    I use a magic mouse with onshape with no issues.
    Like Lou says, I have the rmb enabled in osx preferences.
    I use onshape's settings with the zoom wheel reversed.
