Help: Flipping Drawing View of a Sketch
StephenGStephenG Member Posts: 383 ✭✭✭
I was doing some layout sketches in 3D on a plane different from the global XY (Top) plane.
When I create a drawing of the sketch to specify just the key dimensions and add some notes the view of the sketch in the drawing is flipped (a mirror) of what I want it to be...
When creating a view of a sketch the select view origination is greyed out and subsequent add views by projection is non-functional.
Is there anyway I can get the resultant view in the drawing to display the view orientation I want?
    Can you edit the sketch and just select a different sketch plane?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,927 image
    Views of a sketch only show the +ve side of the plane it is sketched on, so it doesn't matter which plane it is on. If you show a sketch on a model view, it can be in any orientation.
    Indeed :+1:
    Depending on what you've got to reference you can have the plane face whichever way you want:-
  • StephenGStephenG Member Posts: 383 ✭✭✭
    @NeilCooke suggestion to include a 3D part (a cube) in the Part Studio that contains the sketches is a good solution/workaround.
    A view can be built using the 3D cube part to control the view's orientation and the individual sketches can be "shown". I have various sketches created on the same 3D plane (poor man's layer capability) and Neil's suggestion makes it possible to turn the "visibility" of "layers" in the drawing view.
    Thank you Neil.
