I seem to be having this issue. Any thoughts?
However, I seem to be stuck when it comes to Safari. I click the "Sign in with Google" button, select the right account, type in the password, then go right back to the "Sign in with Google" button. When I click again, I can select my account again, but don't have to enter my password the second time (which makes me think it actually did the auth correctly).
Any thoughts on what to look at?
Check your security settings in Preferences (the one for the whole Mac): you may have to give permission for the Google credentials to be used.
There's a similar problem on the new macOS for signing into Google File Stream - it may be the same fix.
This link shows what to enable...
http://www.creativetechsupport.com/help/google/mac/filestream.html
Good luck!
I added Linktab and went through the authorization dance successfully but I can't seem to get it to do anything beyond create a tab in a document. There's no box to enter a link.
FWIW I'm using Google Chrome on MacOS 12.0.1
Is it actually working for you? I've never been able to get it to work in Safari or Chrome.
@S1mon
Yes. I use Brave, its Chromium based.
@lougallo
Are you using Brave on Mac or Windows? On Brave/Mac I'm getting "accounts.google.com refused to connect" when I just add a new Link Tab to a document. I didn't even get the option to enter a URL.
I'm sure this must work for some people, but so far I have never seen Link Tab working. What is going on here?
Windows 10
@lougallo or anyone else can have a look into it.
Thank you in advance.
CAD Engineering Manager
However, the link to https://www.makeitfrom.com/ works just fine, even allowing me to navigate inside the Onshape tab.
For the unsuccesful cases, I also noticed something odd. If I click on the "Disconnect link tab" icon on the upper left corner
and then I re-authorise the connection of Link Tab to Onshape, two new icons appear on the upper right corner, "Open link" and "Reset".
And the Open link button redirects me to the website opening a new browser tab.
This Open Link button was not shown initially, only after reauthorising.
