What surface based software works best with Onshape?
I want to create some surfaces that are beyond the capability of Onshape (so far
) but I still want to use Onshape for most of the mechanical CAD work.
Is anyone using any free or low cost software that can create Onshape (e.g Parasolid) compatible surfaces? Yes, I know Rhino is great but I can't afford that as this is just a maker project.
Ultimately, I'd be doing a split face or replace face with the geometry in Onshape.
michał_1 Member, Developers Posts: 215 ✭✭✭
Best from cheap:
http://moi3d.com/ just 295 USD
example:
by lyes.
MoI is not capable of creating a-class surfaces, but still is powerful. It shares same engine as Rhino.
If you really short on budget, then try ViaCAD only 99 USD:
http://www.punchcad.com/p-27-viacad-2d3d-v9.aspx
5 -
adrian_vlzkz Member, pcbaevp Posts: 297 PRO
Recently came across this one, not sure if it will work for what you need, but looks interesting:
http://cyborg3d.com/index.html
CAD Engineering Manager5
example:
by lyes.
projektowanieproduktow.wordpress.com
I don't now way to get a nurbs from Blender.
