Cannot load drawing and cannot report a bug
Dear All,
I have tried creating several documents and then a corresponding drawing, but the drawing never loads. In some cases i can see a thumbnail of the drawing when i hover over the tab with my cursor, but that's about it. When i try to report a bug nothing happens, while all the other functions work. Please help.
Thank you for your help in advance.
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 417 image
    Hi @hristo_goumnerov, are you in an environment where hosts or ports are blocked going outbound?
  • hristo_goumnerovhristo_goumnerov Member Posts: 4
    Hello John,
    Thanks for the quick reply. I'm accessing the internet via a company proxy/firewall so it may be the case that some ports are blocked. However, i have tried loading a drawing for the same document from my home computer and had the same issue.
    I just opened the drawing on your document without any issues. Do you have any errors in your browser console?
    For what it's worth the drawing in the link above opened in just a second or two for me.
    When i load the document/drawing i get the warnings and error in the attached image.
    @hristo_goumnerov
    What browser are you using?
    Hello again, I'm using Firefox. When i do the system check, everything is fine and i get green checkmarks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Do you have any browser add-ins/extensions running like Ad blockers? Try disabling those. Also in the console error you posted above, what does it say in the SecurityError if you expand it (click the red arrow)?
