How can I make an array of points created by a for loop in featurescript?
emory_krallemory_krall Member Posts: 15 PRO
edited September 2019 in Community Support
for (var i = 0; i < numberOfDowels; i += 1)
            opPoint(context, id + ("locationPoint" ~ i), {
                        "point" : toWorld(cSys, vector((fenceDistance + (dowelSpacing * i)), 0 * inch, 0 * inch))
        var locationPoints is array = evaluateQuery(context, qCreatedBy(id + ("locationPoint" ~ i), EntityType.BODY));
This gives me an error that the variable "i" is not found. If place the variable declaration within the for loop I can't reference it outside the loop, which is what I need to do.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,923 image
    i does not exist once outside the curly braces of the for loop. There are a number of ways you can do this, but it all depends on the rest of the script.
    This is the most elegant way but may fall down if you have other similar loops in your code (due to id hierarchy):
        opPoint(context, id + i + "locationPoint", {
    var locationPoints is array = evaluateQuery(context, qCreatedBy(id + ANY_ID + "locationPoint", EntityType.BODY));
  • emory_krallemory_krall Member Posts: 15 PRO
    Is "ANY_ID" meant to be used literally? When I try this I get the error "Typecheck canBeId failed"
    Yes, ANY_ID is a wildcard. Make sure it is spelled out exactly as above. I think you may be safer using the second method.
    Id hierarchy is a little difficult to follow: https://cad.onshape.com/FsDoc/library.html#Id
    Thanks Neil, your second suggestion appears to work for me!
    There is a typo in the code: "EntityType.Body" should be "EntityType.BODY"
    Yeah, sorry - I hand-typed it from memory. I've edited the post above for anybody else that might copy it.
