How to Rotate Text
I'm trying to use the "circular" tool on text, and it's not allowing me to select the text.
Is this normal? (If not, I'll post an example to help clarify)
Either way, how can I create text in a circular rotation?
In this case, I've created a spinning top by revolving a spline, and now I want to extrude text into the top of the spinning top, but I want the extruded name to be repeated along the top edge of the spinning top. How can I do this?
