Improvements to Onshape - October 1st, 2019
It's the first of October, exactly 20 days have passed since our last update and we are ready for another! This update focuses on usability and performance improvements in many different areas of Onshape. Let's dig in.
has been added to indicate "Latest Revision."
CAD IMPROVEMENTS
HOLE TABLE IMPROVEMENTS
We announced the addition of Hole Tables in our last release. In this update, we've made multiple improvements that make them easier to use.GEOMETRIC TOLERANCE SYMBOL IMPROVEMENTS
You can now attach Geometric Tolerance Symbols to dimension extension lines in Onshape Drawings.SHEET METAL IMPROVEMENTS
Improvements have been made to Sheet Metal in Onshape to better handle multi-edge bends in a single feature. This makes Sheet Metal more robust in situations where you have cuts across the bend.SEARCH RESULT IMPROVEMENTS
Part number, revision, and state now appear below the name when searching in Onshape. This makes it easy to see important information about the thing you are searching for without needing to open it. You'll also notice a new icon
has been added to indicate "Latest Revision."DOCUMENTS PAGE IMPROVEMENTS
You will now see the most recently edited branch when viewing the Documents list from the Documents page.
"SWITCH TO" CONTEXT MENU IMPROVEMENTS
When right-clicking a part in an assembly and using the "Switch to" command, you will now see icons to better delineate between the Part Studio and Assembly.
glTF EXPORT OPTION
You can now export parts and assemblies to the glTF file format.
LARGE ASSEMBLY PERFORMANCE IMPROVEMENTS
Changes have been made to improve large assembly performance in several areas. This includes changes that allow Onshape to open bigger assemblies, improve selection/highlighting performance, and decrease load time.ENTERPRISE IMPROVEMENTS
DASHBOARD PERFORMANCE IMPROVEMENTS
Performance improvements have been made to reduce load time of many of the Analytics Dashboards in Onshape Enterprise.LEARNING CENTER IMPROVEMENTS
"INTRO TO CAD" COURSE
You will find a new "Intro to CAD" pathway in the Learning Center. This pathway is composed of four new courses, geared to new CAD users and focuses on understanding how to model in a 3D parametric feature-based CAD system, using Onshape.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
7
ah what a nice surprise to see today! Really elegant improvements. Makes me want to do more with sheet metal and holes.www.accuratepattern.com3
Nice QOL improvements
Thanks for the switch to icons! Now I don't have to label my part studios with a "parts" prefix/suffix
I wasn't even aware you could select the bend radius like that when importing.. I always deleted the fillet's face and did it from square edges lol..
Thanks for the lesson, and the bug fix I wasn't even aware of
4 -
Ok, great improvements
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común2 -
Loving the icons, thanks Devs
Happy Onshaperist over here
Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3 -
Great sheet metal improvement.
1 -
I've been wanting icons for switching for a long time! thanks for that. More icons the better IMO. It's also great to see the sheet metal improvements. good work folks!5
Good changes, but I already miss having my tags show up below the document name. Tags just became less helpful since you have to hav the info pane open to see them. I now have to click on every single document that is shared with me to see if it has been tagged. That's 20 assignments a semester for 52 students. In other words, a lot.
In the future can we include tag names in our searches? Currently you can click on a tag name and see everything with that tag, but cannot find which documents have the same two or more tags associated with them. For me that might be Assignment 1 and On-time and Tuesday Class.
Brian5 -
Nice improvements!
1 -
Nice improvements to Search Results...
...and there's even a little icon that lets you know if it's the latest Release AND the Revision:
Nice work folks.4 -
Awesome, thanks for the update. The search improvement are very welcome.3
I have not tried it yet but hopefully the sheet metal multiple bend edge shows up in the drawings as a single bend rather than multiples.0
@cody_armstrong
What is this in the changelog?
FeatureScript: Ability to name faces and have it export with Parasolid model
What has it changed in FeatureScript?0 -
Oooh, is this the first step towards MBD?
HWM-Water Ltd0 -
@owen_sparks - it's for third-party apps to maintain associativity (for example, name faces for simulation boundary conditions).
Senior Director, Technical Services, EMEA1 -
@MBartlett21 Nothing has changed in FeatureScript (I haven't looked at it myself, but I assume face naming is done with attributes), it is the Parasolid export that has been improved. If my assumptions are incorrect I will let you know!
You can use something likeMBartlett21 said:@cody_armstrong
What has it changed in FeatureScript?setProperty(context, { "entities": someFaceQuery, "propertyType": PropertyType.NAME, "value": someString, "allowFaces": true });which will add a name to a face and this name will be preserved with Parasolid export.
Neil is actually a bit incorrect in that it was the setting of properties that was updated and the Parasolid export that didn't change. We try to preserve properties on export, even ones that aren't possible to create in Onshape and should be true if you upload some foreign data and export it to Parasolid.
Neil is correct that it is work done to allow for third-party apps to leverage named faces for associativity.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com0 -
So... we could
- create a FS to add information on some faces
- export to Parasolid
- Import in SolidWorks
- Run a macro in SolidWorks and read that information
Un saludo,
Take my money!! These are great improvements.Thank you Onshape.3
With all this talk of face properties, hopefully the ability to colour faces and have this hold on export and import will work too soon. Colour faces was a regular feature I used in SolidWorks and I am pretty sure their colours hold after export.7
I love the new course "Intro to CAD".
I´m glad to see that there are many similar things in our own Onshape course in Spanish. But, of course, you have a better team of illustrators ;-)Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
With the latest update on ios, the sketck tab and measurement information are hidden at the bottom
"Solved thanks"0 -
cant wait for mirroring in assemblies3
Un saludo,
gltf
hohoho Merry Christmas!
gltf is a standard for transferring the display list from onshape to webgl (the browser's graphics engine). There really is no need to have this translation unless you want to spin your OS models on your website. It's a developers thing.
This weekend, I'll be updating my website.
3 -
owen_sparks said:Loving the icons, thanks Devs
Cheers,Owen S.On second thought the icons are a great improvement but they could be, um, greaterer.As it stands:-If we want the part studio we click the grey rectangular-ish icon.If we desire the assembly we click the grey rectangular-ish icon...That rather defeats the purpose of icons doesn't it?If we think of every day real world cues, say traffic lights, they're all round lights but we determine an action based on colo(u)r not on shape.I get the feeling that if onshape designed road signs they'd all be grey
Rant mode off, and thanks for listening.Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd3 -
Maybe there is Finnish UI designer? Look at our traffic signs and you see we love icons w/o any text that you just need to memorize and most of them have same shape and color.. And during winter they all turn into white/grey with fuzzy iconowen_sparks said:If we want the part studio we click the grey rectangular-ish icon.If we desire the assembly we click the grey rectangular-ish icon...That rather defeats the purpose of icons doesn't it?If we think of every day real world cues, say traffic lights, they're all round lights but we determine an action based on colo(u)r not on shape.I get the feeling that if onshape designed road signs they'd all be grey
//rami2 -
Thanks for the update Onshape crew. It seems like I really have to dig into my FS and convert those cut-out cylinders into proper holes..//rami2
@owen_sparks
It is very hard to pick colors that are universally accessible to people with different forms of colorblindness. Differentiating things based on shape when possible adheres much better to modern accessibility guidelines.Jake Rosenfeld - Modeling Team3 -
Our state indications on search results, while using colors - do show the full text of the state they are indicating, and so they work for a range of people. We have noticed other modern platforms indicating state or status in a similar fashion.1
I am finding the part studio/assembly icons in context menus much easier to find. I will take monochrome over nothing any day.
becides, the clean/grey look is the main theme on Onshape since the beginning. Until they add custom themes/icon themes, there is no chance they will sprinkle color into the UI randomly
https://youtu.be/OrSvgmTwO1Y
