Unable to define sketch.
Absolute noob user here. I've worked my way through the training videos/courses, up to a point where I'm experimenting with my own sketches. I seem to be running into issues when drawing basic sketches, & I can't figure out where I'm going wrong. I "think" it's something to do with when I offset lines & arcs. Here's an example of a sketch, I've tried to define all dimensions, yet the sketch is staying red, & giving me a warning it can't be solved. Can someone take a look, & tell me what I'm missing. Please. https://cad.onshape.com/documents/0c0b803967dcb44e84963886/w/fa7385ac3ebfce54e4c02c34/e/d807f0df43aac6ac10c191e1 If there are any more videos/tutorials on sketching techniques that anyone can point me in the direction of, I'm absolutely more than happy to work through it myself. Cheers.
NeilCooke Moderator, Onshape Employees Posts: 5,896
After you’ve deleted the duplicate dimension you should pick one of the blue edges/vertices and wiggle it around to see how it moves. That will give you an idea of what is missing.Senior Director, Technical Services, EMEA5
I see in your first example, you're getting a little drop down tab/menu, telling you exactly which entities are over defined, & allowing you to delete them from there. Is that only available in the phone? app, or is there something similar in the desktop environment?
Once again, thanks for the help, cheers
YOU MENTIONED — I see in your first example, you're getting a little drop down tab/menu, telling you exactly which entities are over defined, & allowing you to delete them from there. Is that only available in the phone? app, or is there something similar in the desktop environment?
I don’t use Onshape on a browser, so I’m not sure, but I think if you hover your cursor over a constraint symbol, that a pop up will tell you if it’s over defined. Somebody who uses Onshape on a browser should jump in here and either confirm this or tell you how to find the desktop equivalent.
And the part you mentioned about getting unexpected results when trimming — sometimes you need to make sure that the endpoints of two lines that appear to be contiguous, actually have coincident points. Like @NeilCooke said above, see if you can move anything around. For example, in the GIF below, you need to make the two end points coincident. Then you’ll have a fully constrained sketch
