How do I extrude the chamfer on this shaft piece?
s_t920s_t920 Member Posts: 2
I'm trying to extrude an imported shaft.  The flat surface was easy enough to figure out, but now I've got to bring out the chamfer.  Not sure how to do that, please help?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,969 image
    Not sure what you are asking? If you want to remove a chamfer you could try Delete Face or Replace Face.
    Sorry, I don't understand the question. What does "bring out the chamfer" mean?  What is your intent?  To make the shaft longer, shorter, thicker, tapered, plain further up or down the shaft before having a square cross section etc?
    Cheers, Owen S.
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited October 2019
    @s_t920
     Is this what you are trying to do?
