Banana for Scale
frank26080115
Member Posts: 19 ✭✭
There's no measurement tool in Onshape, when I open a model, if it's not immediately obvious, then I have no idea how big the model actually is.
Please implement some form of measurement tool, or a little scale indicator somewhere, or a faint grid on planes that can be toggled.
Or have a button that inserts a banana into the model view.
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 669
Measurement tool is always on. Selections will show the corresponding measurement in the bottom right with a chevron to access other measurements about your current selection.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
This is good example: (Factory trolley)
https://cad.onshape.com/documents/1d2cf2545ca34eaea89dbaab/w/a3ed1bdec4b74b4c84840d97/e/442c4913e93a46a18224faaa
I though it was something like 1200mm by 500mm trolley, image tabs show that it might be a bit bigger..
Edit:
Just noticed you can't copy a link to public model from the document list, you need to actually open the document for getting link that works.
Link fixed.
Measurement tool in Onshape is very good when you get used to it.
This thread is not about sketch scaling though. It's about understanding immediately when you open model what size the model is.
CAD Engineering Manager
Onshape Please get a least a .0001 res on the scale soon.
I can't design anything with .010.
Thanks
