Cannot change configurations in assembly. What am I doing wrong
Right clicking a part and choosing configuration and changing it ends up in a error. What am I doing wrong? https://drive.google.com/open?id=15bnHSf_XpqH5fkzuoFURd_UNsopqE5wN
LearnOnshape facebook group
But, yes, pleas make iR for 0-distance transform
https://cad.onshape.com/documents/65f99f98364608c632718161/w/ef30987a879cb34e09f80fb5/e/4a08ac22c8dd385089d962ef
It's something that isn't very clear because more often than not it doesn't matter, but the order of a union boolean does have some importance. The first instance in the boolean becomes the parent part that all other parts are added to. What that means is that all downstream references to that part will continue to exist and all downstream references to the other parts will fail.
The way you have your Boolean 1 union setup:
What this means is that if 'Part of Linear pattern 2' exists, then the configuration will resolve to that. However, if it doesn't it will resolve to 'Part 16'. And if 'Part 16' doesn't exist, then it will resolve to 'Part 15'. And etc. etc. etc. as it goes down the line.
Since you are increasing/decreasing the number of parts with your configuration, you want to make sure one that exists in all configurations is at the top. This will mean that the reference will be stable and by changing the configuration will resolve properly.
I understand why this happens now but at the same time I cant help but think this should work regardless. Guess I need to submit a enhancement request.
THANKS!
I don’t think there is much point submitting an IR as there would be no way for us to determine the ID otherwise.
