Subassemblies fail in Main assembly
3dcad
Member, OS Professional, Mentor Posts: 2,477 PRO
Does anyone else have problems where main assembly shows errors on subassy and not functioning correctly while looking at subassy everything is good?
This happens to me all the time with certain standard part assemblies (hinges) even though everything is good when building main assy - it may be broken when come back after a while. Subassy is linked so it comes from locked version.
Sometimes this happens for local subassemblies too, those times there is usually mate or two red in subassy and the fix is to suppress and unsuppress and it's good for a while.
I have reported this multiple times and had that hinge doc checked by Onshape but still struggling to keep things together.
Left column subassembly - right same version in main assy.
Kind hard to fix while there's nothing to fix..
2
Intermittent and low-impact for me, but a time-waster. Looks to me like this issue would impact the top level assembly's function in your case.
I had a similar error and this worked for me in the past.
For me it used to be only some rare cases but recently I have bump into this more often - even up to a stage where it's difficult to work anymore. Like today.
In my case it's usually the hinge sub-assy that's claimed to be broken and in main that throws doors around screen and bits of hinge assy flying around.
The most annoying thing that reminds me of traditional cad is that everything is good when making the assy and when coming back later it's like this:
(there should be 6 functioning door fronts)
Sometimes it's enough to grab the door with LMB and just shake for a minute and suddenly it jumps to it's correct position and moves like it should - sometimes not.
Edit: This assembly doesn't even show any errors!
15 pages in total, most of them improvement requests
Happens when 1 mate imposes over an other mate. Both can't be right.
Grouping the parts in the main assembly will cause mates in sub assembly to show as an error when viewed from main assy.
For me it's when I'm in a rush and don't want to take time to finish mating sub assy components to get the proper behavior in the main.
I don't do main assy groups. All these I'm talking about are completely fine at first but break by them self while no one is accessing the document.
One thing I learned today is that planar and parallel mates are expensive and apparently can't be used to connect two (or more) moving parts move together. At least not without problems.
I'll watch for it.....
Well at least it was when I modeled this back in 2017.
Now Onshape claims that one of three door assemblies have problem with mates and throw that hinge piece flying around. But they come from same subassy - how is it even possible that two is good and one fails?
When first accessed this tab, there was 2/3 fail but with just simply grabbing the door and shaking mouse with button pressed for 1-2 min it suddenly start moving and problem wen't away.
Support has been very helpful and all over it but not being able to make the problem go away.
It's a bug - there is no way to fix by modeling. A simple 12 part hinge just seems to be too much at the moment.
But Onshape has the history, let's go back to here - and *zap* all good again
Let me present you fully functioning cabinet with 3 doors moving flawlessly within realistic limits - without any errors.
And can't make it fail anymore no matter how much I slam the doors.
