Sheet metal tab connecting two flange parts question
william_holden959
Member Posts: 32 ✭✭
I'm trying to use a tab that connects two flanges. It works (with an error) but it won't let me flatten the part. I'm open to drawing this another way. If there was a sketch bend I could do that way. Any suggestions are appreciated! (Unrelated: Once I used a sheet metal CAD that let users add flanges at 0 degrees which came in handy for doing what "tabs" is currently used for it seems.)
https://cad.onshape.com/documents/0eb35e825b6d71689fe188cf/w/d21bd2f3258af32ed38df233/e/58013e8c99bc00ee4aae1c01
OptionsNeilCooke Moderator, Onshape Employees Posts: 5,402That is a limitation of the tab feature. I would model the whole thing as a solid flange then add the cutout later.Senior Director, Technical Services, EMEAI6
Does that doc still exist/is it public? I am getting a not found when trying to look at it. My first instinct based on the conversation here is to suggest "move face" for extensions, but I would have to see the specific case here.
