Basic sheet metal part construction
Marc_Miller
Member Posts: 111 ✭✭✭
Hello all.
I haven't used sheet metal in Onshape before and wanted to ask how others would go about modeling this simple bent bracket? See attached sketch.
What route should I take to model this? Will be using 1/16" Aluminum.
Thank you for having a look.
NeilCooke
Moderator, Onshape Employees Posts: 5,932
Assuming the positions of the holes are the most important factor, this is probably the best/easiest way to do it:
https://cad.onshape.com/documents/51578fc4c7a75594928c5b6d/w/02c5fb240941ebc111d93b4f/e/672bd57c2bef1b37a217c1f2
BTW the last sketch was done on the flat pattern (tab on right of screen)Senior Director, Technical Services, EMEA3
https://cad.onshape.com/documents/602655eff016f183fc184978
Oddly the example above in this thread I cannot view the magical sketch being used on an iPhone:
Ah, the sketch exists within the sheet metal flat pattern screen that is inaccessible on mobile, which is why it can indeed magically operate on two orthogonal surfaces in one move.
@NeilCooke Will the sheet metal flat pattern eventually be able to be viewed on phones/ipads?
