how to configure color of part in assembly
mike_gibson022
Member Posts: 3 ✭
Is it possible to have two instances of the same part with different colors in an assembly?
john_mcclary
Member, Developers Posts: 4,004 PRO
They will allow you to have 1 unique color per configurable permutation.
The easiest way I find is to open the bom in an assembly, add the appearance column and set it there. It's a little more intuitive than doing it in the in the part studio5
Instances of the same part cannot have unique metadata.
If you have at least 1 configuration parameter, then each configuration is concidered a unique part. Then you can change the metadata for that part (config)
For instace, add a checkbox config and call it transparent.
Insert your part twice. Change the second instance to be checked.
In the bom, add the appearance column and change the value of one of them to be transparent.
