Suggestion or help - Trying to remove material on a sphere with a drafted cut
mj_powersmj_powers Member Posts: 18 PRO
Hello,
I'm trying to model a hamster ball and I need to cut out air/drainage slots.
I need to remove material with a draft.
I thought I could create a surface and then thicken it to use a boolean subtract - but the thicken has no draft.
Any suggestions? I will also need to pattern the feature around the spherical surface
thanks,
Matt
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 554
    @mj_powers There should be several ways to skin the cat here.  I might model a body/part that represents the removal and use a draft feature to make the draft as you want.  Next, boolean subtract the removal part.  Next, face pattern the faces.
    I agree with Pete except for the face pattern.
    I would create a tool to "stamp' the contour (like Pete said) but then "Part - Pattern" that around the sphere with the "remove" option selected.
    That should save you a feature on the tree and a bunch of selections. It will also make your pattern update properly if you modify the tool body by adding fillets or something later on.
  • mj_powersmj_powers Member Posts: 18 PRO
    Thanks - got the feature worked out by creating a stamp - cut - pattern.
    But, honestly if the Thicken feature had a loft option this would be a no-brainer simple way to make drafted cuts and holes in curved plastic surfaces.
    Just wondering if adding draft option to the thicken command is already in the "feature request" section???
