conditionally reference a variable
EvanReeseEvanReese Member, Mentor Posts: 2,697 PRO
edited December 2019 in FeatureScript
I'm working on a multi-variable feature using an array parameter. I'm looking for a way to optionally reference a variable that's earlier in the array. Here's what I'm trying to do, but it doesn't like it.
I think it doesn't like it because the feature isn't finished until I hit the green check, so it can't see Var1 yet. I believe I can use getVariable() to access it in the featurescript, but I'm stumped on how to make that conditional. I want it to be something like if (Variable contains "#" then grab the variable name and use getVariable(), else, just use the number that's there). I have even less of a clue on how to make that work if I wanted to reference 2 variables at once, like Var3 = #Var1+#Var2.
how can I find any word using a # and convert that to a getVariable function? Or is there a much simpler way?
The code is here if you'd like to see it
  • john_mcclaryjohn_mcclary Member, Developers Posts: 4,005 PRO
    Just a shot in the dark but.
    Can you create a loop at the beginning of your code that creates a map that has this format: Vars [id, name, value];
    that stores all of the created vars sequentially.
    I'm not sure if you can parse a string in FeatureScript though. But otherwise I'd parse the value of each variable and to a replace #xxxx with whatever Vars[] has a matching "name".
    Vars[2].value = Vars[1].value * 2
    I probably don't have the syntax right, but you see what I'm getting at?
    Then you setVariable(context, Vars[n].name, Vars[n].value); in a loop at the end
    Just if anyone comes across this thread, we ended up getting it to work here:
    https://forum.onshape.com/discussion/comment/58476/#Comment_58476
  • EvanReeseEvanReese Member, Mentor Posts: 2,697 PRO
    haha, "we". @m@MBartlett21 got it to work and I watched. I do still use that feature in most of my models though!
    Yea, thats about how it goes when he helps me too.  Just get out of the way and watch him go.
