Can’t open doc on desktop
steve_shubin
Member Posts: 1,118 ✭✭✭✭
I’ve been using Onshape on my iPhone for a few years. It has worked great for me on my iPhone.
I’ve only tried Onshape on my MacBook Pro once before and I had no problem opening a document and playing with the drafting features.
Today, I got out my MacBook Pro and tried to open up a document. Every time I selected the document and tried to open it, the program came up with a message saying — a problem repeatedly occurred with — and then it gave the URL for the document. And there is also a button that says — reload webpage
What am I doing wrong
I’d appreciate any help
Can you open a new document, or is it just that specific document?
You should click the "?" icon in the top right corner and contact support, don't forget to toggle the "Share document with support" option as well.
You will get much quicker and more direct help from the official support team.
First off, thanks for the quick response John
Safari ver. 13.0.3
So far it looks like I cannot open any document
I even tried a system check and that failed
I’m a hobbyist and it doesn’t look like I have access to support, or at least not that I can tell
I wonder if it has anything to do with my firewall settings or something like that
I really don’t use my computer much anymore. I primarily just use my iPhone so I’m a little out of practice with my MacBook Pro. But I did try Safari on my MacBook Pro to click on other websites and I had no problem
Puzzling
For what it’s worth, the version of my operating system is MacOS High Sierra version 10.13.6
I’m using a MacBook Pro 15 inch 2017
2.8 GHz Intel Core i7
And it’s kind a hard for me to think that my computer would be defiled in anyway because I rarely use it and I don’t use it for surfing the Internet at all
Since I bought it, I’ve accumulated a minimal amount of hours on it
Also check to see if webGL is enabled.
If you could try firefox or chrome also to see if it just a safari problem
But I was looking into that WebGL stuff you mentioned, so I’ll let you know what goes on once I install Catalina
Again, thanks for the help
Yeehaw !!
Installing Catalina did it
Thanks for your help John. I’m sure I would’ve gotten discouraged if somebody wasn’t working with me and I just would’ve closed up this MacBook and put it back in its case
I hope you find the desktop version of Onshape much easier than the mobile apps.
