How to make a hole normal to a revolved surface
john_lombardo
Member Posts: 20 EDU
How can a remove-extrude be set up to extrude normal to a surface created by a revolved profile? In this piece all the holes are normal to the top plane, but I'd like some of them normal to the inverted cone surface created by the revolve. I don't see how to draw a circle on that surface.
https://cad.onshape.com/documents/271189896c528a34616e49e0/w/939931ff7028104b68f56756/e/fc844516e3a0c8ab40ac1a5d
OptionsPrachi Member, OS Professional Posts: 262 ✭✭✭An other option with no feature script.
See modification to your profile sketch.
Use implicit points @ end of lines to make holes.
https://cad.onshape.com/documents/251d4abcdfff2fcab1417769/w/df8edb92f434063bddc3bec0/e/1ed6159233b891454ad83d72
5 -
Optionssteve_shubin Member Posts: 1,068 ✭✭✭✭
It would be nice to have the ‘inferred Mate connectors as points’ for the Hole tool on mobile
5
https://cad.onshape.com/documents/68e4a25529cc0ee1fb519e2f/w/692b70287001d03650977810/e/0f4627bf74d98cb7b60bbeb7
https://cad.onshape.com/documents/68e4a25529cc0ee1fb519e2f/w/692b70287001d03650977810/e/d8b8425840b594d51368f049
Making a plane at the end of a short line added to the profile worked for me using curve-point as the webinar (https://www.youtube.com/watch?v=zCGFUCBDu7w) at 27:45 shows. Thanks for the idea.
Steve: I was able to make some planes but couldn't get one to look like yours ( I got just about every other angle, though!). I am missing something, but for now I can go on with the project.
Thank you two for making this the best forum this newbie has ever encountered!
