Portable Air Cooler
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
I am designing the heat exchanger for the portable air cooler. I want to extrude the 4 circles through all of the heat exchanger fins and replace the circles with tubes going through all of them. Please show me how to accomplish this feat.
https://cad.onshape.com/documents/4bcfe478c3a8d738998fb396/w/31b4a1c2d937511e77983be9/e/ca7cceaf16668d9489d79312
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    Your best place start is to go through the Onshape fundamentals self-paced course: https://learn.onshape.com/learn/learning-path/onshape-fundamentals-cad
    You will want to extrude your fins as solid parts and then using the power of a Part Studio you could extrude the tubes to go through the fins and connect everything. Sections 2,3, and 4 of the fundamentals CAD pathway are where you want to look.
    Twitter: @bradleysauln
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    I look at it see if it helps.
    I tried everything; Up to face; etc, but I couldn't figure out the merge command. The fins are not touching but I want to extrude  4 holes that go through all of them after which I''ll do and extrusion as a new part for pipes that go through the holes, Please help.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,912 image
    You've patterned a bunch of sketches - they need to be solid parts before you can make holes in them. Please review the free training videos.
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
