NVIDIA® Quadro® P600
michael3424
Member Posts: 747 ✭✭✭✭
in General
Are there any benefits or downsides to using the above video card with Onshape?
I'm about to buy a new PC and and this card is the only "official" replacement for a built-in Intel video chipset.
Is this a used PC or a new one?
Best part of Onshape is, you can log in and benchmark it before you buy it. Which I would recommend.
Otherwise, most any discrete card should be better for Onshape than the intel chipset. I haven't had much love with the intel video in Onshape.
It isn't bad, but it is noticeably worse than when it is running on the discrete chip.
1. Checkout sites such as https://www.videocardbenchmark.net/gpu.php?gpu=Quadro+P600&id=3729 that provide more information
2. Search online for any bugs reported against the card. FYI, I did a quick search on in our bug database and did not find anything specific to this card.
Depending on what you are modeling, If you have large assemblies, the more memory you can get, the better it is for performance.
@john_mcclary - I'm looking at buying a new HP Z2 mini workstation. The alternatives to the Quadro P600 appears to be a Quadro P1000. an AMD Radeon™ Pro WX 4150, and the integrated "Intel® UHD Graphics 630". I doubt there is anywhere near me in the Chicago suburbs that sells this model PC and has them available for demo so testing benchmarks for myself is probably not likely. It would be interesting to see if HP was willing to run them and report back or maybe someone here is using a Z2 Mini and can report.
@Paul_J_Premakumar - Thanks for benchmark site link. I'll check that out.
I am semi-retired and using the free Onshape plan for my hobby and non-paying design projects and Alibre Design for the small amount of paid work that I do. The former is mostly just a few parts with no or very small assemblies but I still plan to get more than the default memory.
One reason for the question is that my current PC is an HP Z400 workstation with 18 GB RAM and a Quadro 600 and does not perform very well on the Onshape - it gets:
Which a bit worse than most get. My speed in Onshape seems mostly OK with a bit of a lag which is noticeable but not super annoying.
@pete_yodis - forget to actually post my reply to you, but the PCs I'm looking at are not usually carried by Best Buy and the other store front sellers near me, so testing before purchase is not an option. I'm pretty much stuck with word of mouth.
Measured triangles per second
All the hard work is done on the cloud. you just need to rotate and zoom reasonably.
I usually follow the philosophy: Buy the best you can afford, upgrade less often.
I'm running a RTX 2070
just a quick newegg.com search of a Quadro p600 and a RTX 2070 is about double ($200ish)
but the performance is about 15 times higher (with the cheap laptop Max-Q version, while running solidworks in the background with over 2 gigs of memory taken up). Seems like a very significant bang for your buck, I can only image the desktop card is better.
It is usually better fans and heat sinks and cases that they add between brands.
