Make mirrored part a new part
How can the mirrored part be moved to the front plane along with deleting plane1? in other words, I want to clean this part up so it looks like a new original.
https://cad.onshape.com/documents/41e37808df9fac617da22443/w/3b22eacc992851cdbc7eb510/e/21fb5dc39d2b3daf928bf49e
steve_shubin Member Posts: 1,111 ✭✭✭✭
@john_lombardoYOU ASKED — How can the mirrored part be moved to the Front plane ?
In this case I would go into the features list and extrude in the opposite direction. That is, I would alter the direction of my original extrusions, so that they go in the opposite of what I had first made. I think this would be the best way to — CLEAN THIS PART UP, as you said. See the link in this post.
Take note of how the number of steps in the features list has been reduced as a part of cleaning up.
If I wanted something other than the largest surface of the part coincident with the front plane, then I would employ Second End Position on the various extrusions of my part
A sidenote — your sketch is not fully defined. The lines and points in your sketch are blue. Take some time to fully define your sketch. Otherwise you might accidentally drag elements of your sketch around. Fully defining your sketch would definitely be part of cleaning your document up.
7 -
@john_lombardo
this sketch is fully defined other than one point that isn’t critical. Everything is black except the single point
5
You can hide them by clicking the "eye" icon that appears next to each feature in the Feature List:
The "ghosted" shape that shows with Sketch 2 is there because you created that sketch on a face of the model, instead of on a Plane.
Romeo
https://cad.onshape.com/documents/3f9ca748fc5a9d26b2c1d289/w/48d7b60500174bc483d8046f/e/e4167596a3ef6f51ebaad298
