query strategy
EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
I'm adding a new Slot Circle mode to my Speaker Pattern feature that makes something like this:
I want to fillet the internal corners of the cross-brace member. I'm able to query all of the edges produced by that cut, like this:
I think I should be able to qIntersection that with a query for all of the edges parallel with the normal direction, but I'm not sure how to do that or if that's the best way. Any ideas?
  • EvanReeseEvanReese Member, Mentor Posts: 2,856 PRO
    Well, that definitely works, but I'll have to comb back through it with a fresh mind another day to figure out why exactly. Since this feature is also a self-imposed, project-based learning exercise, followup questions are likely. Thanks, Kevin!
