Im unable to select or delete named views
nicholas_witham
Member Posts: 17 ✭✭
I have an arrangement that has/had 2 different named views, but I am unable to select them as I get an error code.
Im also unable to delete these named views.
As these named views seem to be broken, I created some new named views that do work.
The named views that don't work are the ones in upper case, and the named views that do work are sentence case.
Is there a way to delete these "broken" named views?
https://cad.onshape.com/documents/1d0adc94f0192fbb520130ba/w/80d0543ae61c2d6d8e387578/e/49fc6d2085cc63e7952519da
Have you tried clearing your browser cache?
So they are already deleted.
Are you still seeing them?
press F12 then right click your refresh button and select empty cache
Im surprised you can't see the same views I have
