Linear Pattern - Issue with Qtys
POC
Member Posts: 25 PRO
The linear patter routine is duplicating parts incorrectly, doubling the required qty..but visually looks fine,, however results in incorrect BOM qty's. This was not the case previously...
1
if you were to select a direction perpendicular to your first direction, you will see it makes a 2d array of your seed parts.
instead of first direction patterning north
and second direction patterning south
only pattern north 6 instances.
Solidworks has the option to "pattern seed only" which fixes this issue.
I think you should create an coupe of improvement request for this (Or I can if you like)
One for "Pattern seed only"
and another for "Centered Pattern"
https://cad.onshape.com/documents/57b77f0de4b0a399ffb138eb/w/65d6f78c04fa81878bb2e0e4/e/a0f2afc7f1c42d09f31ac5db
This is assemblies though
Funny, I went looking to see if that was an existing improvement request. Turns out you're the one who submitted the request. Everyone vote here.
https://forum.onshape.com/discussion/9663/featurescript-for-assembly
We came very close to paperless... missed it byyy thaaatt much..
