Creating Multiple Lofts from Linear Pattern of Circle Sketches
Hello,
I'm creating a practice 3D print for tapered heat set inserts to determine the right size. I'd like to create an array of lofts between various sized circles on a rectangular prism.
Here's my part: https://cad.onshape.com/documents/0fd63e74f8558ca407410cd8/w/150d7ed514b4c73afde5d7d4/e/c63e92e94cc05653e7b3026e
My two questions:
1) how can I create multiple lofts at once? (OnShape only seems to allow me to make one at a time and I can't pattern the feature after)
2) what is the best way to create an array of circles that increase in size by a certain amount at each location in the linear pattern or how can I ungroup them after patterning them to change each of their dimensions slightly
Any advice is much appreciated!
My two questions:
NeilCooke Moderator, Onshape Employees Posts: 5,844
Here's how to do it with a linear increment:
https://cad.onshape.com/documents/508c9bf00f382b583a6bfca8/w/6d09f3056925703ec4445b99/e/3ecfed97de8a6ecdeb1376a8
If you want more control, you would have to do each one manually.Senior Director, Technical Services, EMEA8
