dxf import to sketch?
scott_caskeyscott_caskey Member Posts: 53 PRO
Can you import a DXF drawing as a sketch?   Convert it to a sketch after you import it?    When I import dxf files, they are uneditable.
    Yes, import to Onshape, insert into sketch, then project the geometry you want onto the sketch, modify as you wish, then export again.
  • scott_caskeyscott_caskey Member Posts: 53 PRO
    How do you insert it into a sketch?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,859
  • jannie_smaljannie_smal Member Posts: 7 EDU
    The above is not working,This is just not working with Onshape, please let me know how to use it in a sketch! I get it in a TAB but cannot use it to make a part from it
    @jannie_smal did you click the help link above? You have to create the sketch first.
  • luis_carvalho222luis_carvalho222 Member Posts: 8
    Hi, I had same problem, in this exactly moment. Was looking a way to solve it and this was i did:
    1 - Imported a coreldraw crated .dxf file
    2 - RMB on the tab imported and created draw from dxf;
    3 - Export drawing to dxf from onshape to a new tab
    4 - Imported dxf from current document.
