"Zoom to fit" Improvement
2»
  • StephenGStephenG Member Posts: 383 ✭✭✭
    Well, it looks like it is not fixed. (Tested file attachment with another post and it worked. Problem appears to be specific to this post.)
    Attempting to upload a new version again. This version separates Keyboard shortcuts from Mouse behaviors; mouse behaviors are on a separate page. Having both on the same page made it cumbersome to maintain and visually confusing. It is now a 2 page (2-sided) reference card.
    Still cannot upload files to this post.
    Decided to provide a link to a PDF file in a cloud storage site: https://1drv.ms/b/s!AuMUtTIiNawOvDe-SNdct8pfq6n4?e=adySk7
    edited January 2020
    Deleted duplicate post
    edited January 2020
    @StephenG
    Excellent!  I learn something every time you bring one of these out.  This time: LMB double click - select associated feature AND Ctrl LMB - Select entity and open Context Menu.
    Thanks for doing these the new formatting is great!   :)
    www.accuratepattern.com
    @StephenG
    Suggestion for 'Sketch' section -  'Square rectangle'  which is Alt LMB while in either of the rectangle tools.
  • john_mcclaryjohn_mcclary Member, Developers Posts: 3,952 PRO
    @StephenG
    Oh damn! That's awesome, I wasn't aware of that one. Thanks
    Thanks for pointing out the undocumented keyboard short cut in the onscreen "?" pop-up. (I see ALT g is documented in the on-line Help.)
    Incorporated ALT g into Keyboard Quick Ref. Guide.
    New link is: https://1drv.ms/b/s!AuMUtTIiNawOvEMtR6sC3VFN9LZi?e=7PDmuk
    Onshape Update: 4/17/2020 (1.112)
    Added new keyboard shortcut Shift t Transparency to 3D Viewing section.
    Added comment to Shift s Create sketch: Use a Plane or Mate Connector instead of a face to define a sketch plane with no edge imprinting. A Mate Connector adds a local Coordinate System making it possible change the orientation of a Horizontal/Vertical constraint.)
    Added comment to ? Display keyboard short cut: Selecting the arrow (upper right corner) converts the popup display to a proper window.
    Also added comments to a few sketch functions that have different behaviors when the LMB drag is used.
    l-Line (LMB drag creates single line segment)
    Shift f-Fillet (LMB drag resizes the fillet)
    o-Offset (LMB drag resizes the offset. Shift LMB drag chains connected curves.)
    Here is the new link: https://1drv.ms/b/s!AuMUtTIiNawO0iGBddmiJHejtz_s?e=gAcUyl
    Onshape updates: 5-13-2020 (1.113) and 6/3/2020 (1.114)
    Added new keyboard shortcuts to 3D Viewing section:
    •  p - Hide construction geometry
    • Shift i Isolate
    • n - View normal
    Also added Shift y - Show selected back in which was accidentally deleted in prior versions.
    Here is the new link: https://1drv.ms/b/s!AuMUtTIiNawO1DkAdPMrWf8Gt5TQ?e=JQ3EyZ
    @StephenG
    You got all the ones I wrote on my copy by hand.  This is a great reference and training tool!  Thank you for keeping it up!
    @StephenG
    One thing - Technically 'Alt g' is not right.  It is  Alt LMB drag to create square in both rectangle tools (g corner rectangle and r center point).
    Might be best to put a parenthesis under g and r like:
    (Alt LMB drag for square)
    @bruce_williams
    Thanks for the critique. I have made the necessary changes to clarify this behavior.
    Revisited wording of Shift s-Create sketch and o-Offset  embedded comments and improved the wording.
    Here is the link to the revised document: https://1drv.ms/b/s!AuMUtTIiNawO1DxHO_GbCv3Iqroq?e=9CRjFg
    Onshape updates: 6-24-2020 (1.115)
    Updated to reflect changes to what happens now with arrow keys:
    3D view rotation steps are now 15 degrees instead of 45.
    Arrow keys with Shift key are now 5 degree rotation steps instead of 10% of screen pan.
    Here is the link: https://1drv.ms/b/s!AuMUtTIiNawO1HF5uYZOnJQaF5hU?e=xq4vzZ
    Incorrectly assumed Arrow Key panning was lost when Shift+Arrow Key function was changed to 5 degree rotation steps.
    Keyboard equivalent for Pan function is now Ctrl+Shift+Arrow Key.
    Link to corrected doc: https://1drv.ms/b/s!AuMUtTIiNawO1WKmh5mYPu7Bdxus?e=I8DBUg
