Simultaneously invert the suppression state of a group and the associated mates
A nice function, maybe it's already available, would be to select and single click invert the suppression state of a group mate and the other mates associated with the group. This is key for large models, where you want to group things together and hence suppress the mates that are associated with the parts in the group, but to make changes you want to invert those states of suppression, i.e., unsuppress the mates of the parts, and suppress the group mate. Probably a script could do this easily, I just don't have the bandwidth at the moment to create one.
billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,100 PRO
I believe you could do this with configurations.
5
I'd look into named positions also. If you have automated equipment that moves through different stages; you can name these positions 1st pos, 2nd pos etc... Named positions will over ride mates; which they should.
On top of that; create incontexts at each position. This way if you have a universal nest; it'll update based on the position it's in and that context.
Named positions with incontext is really powerful & less restrictive than config & suppressing and a joy to use.
