New Using Assembly, having issues with linkage motion, all revoultes
The seventh resolute connection causes all resolute to fail. Looking at the design... the large gear rotates in either direction, no limits. All other joints/ connections rotate based on the large gear rotation and are limited by the linkage interconnections. This is a classic Klann Linkage design.
I'm missing something obvious. I've gone through the self learning provided.
TimRice Member, Moderator, Onshape Employees Posts: 315
Try switching one or more of the revolutes to cylindrical mates. There is possibly a misalignment in your assembly and the revolute mates are causing too many degrees of freedom to be removed.Tim Rice | User Experience | Support
Onshape, Inc.5
Onshape, Inc.
