Change reference part in sheet or drawing
paul_bunnell
Member Posts: 26 EDU
in Drawings
I had a nearly finished drawing then made a change to the model that created two new parts out of some "scrap" area of the first part. The drawing views all reference "part 1" but when I changed the model, one of the scrap parts became "part 1" and the main object became "part 2."
When I went back to the drawing I figured "no problem, I'll just edit which part from the studio the view is referencing" but as far as I can tell, that is not possible. Am I missing something?
If what I am looking to do is not possible, I would say as a general feature request, any option that can be selected when something is created should be editable after it has been created.
1
It would not be possible to switch which part the drawing references because each edge/vertex reference would be different and the dimensions would not know where to go.
Is there a possibility of being able to edit the internal ID of parts
right-clicking then clicking on sheet properties -> right-clicking on sheet tree origin gives you a chance to replace the root part ID, I tried it and salvaged 80% of my dimensions
Thanks a lot!
