BOM cross-reference parts
I like Onshape's new built-in BOM feature. And it's good that when you click on an item in the BOM, it highlights the part. But really, my prototype assemblers need it the other way around - so when they click on a part, it highlights in the BOM and they can know what part # it is, etc.
Do you know of any way to get this type of functionality? Because it's somewhat tedious to have to skim through the whole BOM to find the part of interest
1
If you click a part it will highlight the part in the tree.
So if you add "Name" Column to the BOM then you can find it that way.
You may want to create an Improvement Request on the right -->
But what I typically do is rename each part like this "PartNumber - Description"
If you copy your BOM and paste it into a spreadsheet, then you can create a quick formula that combines your "description" and "partnumber" columns then paste it back into the BOM, that will rename all of your parts quickly. (probably 1-2 minutes for 1000 unique parts)
Then you can click the part and look at the part number in the tree instead of the BOM. It also helps to have the part names formatted that way for when you export step files for manufacturing.
Here's what mine looks like to set all of the properties in the Parts:
1: Paste raw BOM info into H5
2: Enter some partnumber info
3: Copy the columns you want to paste back into your Onshape BOM
Now when you click a part you will see :
https://forum.onshape.com/discussion/12972/bom-two-or-one-and-a-half-way-interaction-with-parts-in-assembly-studio
