Advice with Extrusion / Intersections / General TIps :)
yuggniiks
Member Posts: 25 EDU
Hi. I'm looking for advice on how to create a hole in an extruded surface.
My goal here is to make the object hollow on the inside, so cone / orange extrusion / and bottom box is hollow.
The cone was made using the Loft -> surface command.
I tried creating an intersection extrusion with the orange section, and it seems to have created the surface for the opening I want through the orange section,
I just don't know how to use it.
In case you want to get more hands on with my fledgling modeling
Thanks!
