plywood material
don_howe
Member Posts: 117 ✭✭✭
Taken from this site:
https://www.woodproducts.fi/content/plywood
Otherwise I have a material featurescript that can be modified for you.
Let me know if you want to go that route
It will work similar to the current material selection and save its value to the part's material property.
It also sets mass properties and saves the weight in a custom property.
Because you have a free account, that may need to be set to TITLE3 or something.
You can have one feature set the material for multiple parts at a time.
So you only need one feature per material type in the tree.
If someone wants to make the code work with a .csv for the material, that would be great.
Until then, I have just been hard coding material...
Here is a demo of the usage:
https://www.youtube.com/watch?v=sIzpM0Us-rM
