unable to use "Named View" that is sectioned in my drawing
nicholas_withamnicholas_witham Member Posts: 17 ✭✭
In this document
https://cad.onshape.com/documents/1d0adc94f0192fbb520130ba/w/80d0543ae61c2d6d8e387578/e/e1808b7c691e50d344218f03
In my sub-assembly "Carrying Frame_1" I have a named view "Gridmesh Plan (Section)"
I also have a couple other named views.
When I try to use the "Gridmesh Plan (Section)" in drawing "098-M-00007", I can only see the option to use the other named views, but not the one I need.
Is there a restriction from using a sectioned named view in a drawing? Or maybe is there another way to import that named view?
  • lougallolougallo Member, Moderator, Onshape Employees, Developers, csevp, pcbaevp Posts: 2,014
    Currently named views with sections or perspective views will not work. We will address this sometime in the future.
  • nicholas_withamnicholas_witham Member Posts: 17 ✭✭
    ok, thanks for the response.....i'll stop trying to figure it out now.
