Sending a message to the owner
rune_thorsen229rune_thorsen229 Member Posts: 179 ✭✭
Hi when finding something useful among the public documents I'd like to send a message to the owner like asking for permission to use the design or propose a collaboration.
How can I do that?
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,417
    Unfortunately, there is no way to do that - it would definitely be useful for collaboration. Content in Public documents is public domain so you don't need the owner's permission to use it. However, we have no control over what content is being uploaded and whether it is infringing somebody else's copyright.
    FYI for everyone posting links in this thread, the `/e/aa112233bb4455` portion identifies the tab, so once you copy and paste that, everone who clicks it is always going to go to the tab you were currently on when you copied the URL.  If you just go to say:
    https://cad.onshape.com/documents/ea73831031c68a9ca068365e
    The system will have to infer a tab for you.
    So if you ever click a link with /e/ in it, the tab has already been chosen for you.
    Thanks for your quick reply. Then if I want to give people an opportunity to codesign on opensource projects, where would you suggest to put my contact information?
    It's a bodge but you can use "FeatureStudios" to store plain text.
    If you use the comment tags /* and */ at the start and end of the text then OS won't try and covert it into featurescript.
    Alternatively use a link tab to an external document that holds this info, or a PDF tab internally.
    The harder part is making it obvious to the user that this information exists.  Some sort of "landing page" or "splash screen" would help here.
    Cheers,
    edited February 2020
    Hi Neil, negative. I just opened a random doc of the shared. It was NOT the first tab that was displayed but the 3'rd. (https://cad.onshape.com/documents/58235f06ec5f9e10edc676dc/w/282a1c673de4934bb346bbee/e/6490594eb6b6aaac5649f4bd)
    Indeed.  I thought it was the "last used" tab that the document opened at?
    However the idea of a PDF is not bad, is it the only format possible?.
    john_mcclaryjohn_mcclary Member, Developers Posts: 3,902 PRO
    By default if you open tte document from the Onshape document browser.  A link will take you directly to the tab it was created from.
    john_mcclary
    Negative, the tab it was created from doen't seem to matter as this was created firs with a Sketch then the PDF was added: https://cad.onshape.com/documents/0a30ad4b2556d4120059fb8f/w/be7effe649adf04ef4cbb4f5/e/a0bfa12ea865a6eba3c59978
    NeilCooke, may I ask you if it is possible to view the public onshape documents without signing in. For example I referenced a drawing (https://goo.gl/hD9NTT) in our publication https://www.tandfonline.com/eprint/KZSRCKIETT2HABTI9DSF/full?target=10.1080/10400435.2019.1634660
    But I realized that you don't give view access to public documents. If thats the case, it is A GREAT PITY (I guess google documents beat you on that ;-)
    Your link took me to the pdf page sucessfully.  If you're seeing different it's possibly because you're the owner.  What happens if you open in in incognito mode?
    Thanks. I suddenly remembered that one has to take the link from the "link sharing tab" for this to work.
    I'm pretty sure this is how it should work: if you've never opened a doc before, it will open at the first tab. If you have, it will open the last tab you had open. If you click a link it will go to the specific tab.
    If you own the doc then you can link share with non-Onshape users, but you can't send the link to somebody else's public doc.
    If I go incognito mode and open https://cad.onshape.com/documents/ea73831031c68a9ca068365e/w/1a01534a1adf03ae8d93868b/e/33a7d433c37c6c7fe2d4570d
    It opens the tab: Stick_2.0
    If I search FeatureScripBelt and open it, it opens first tab
    https://cad.onshape.com/documents/57886eace4b0e425c1ef548a/w/54f180f432defb41a8fddb17/e/c65e445e89ee373617edc394
    Opening tab belt.svg and closing.
    Searching again it goes directly to belt.svg
    Conclusion: you may be right.
    By the way an exellent example of how to go around my initial question. Thank you so much everyone.
    Rune
    Thanks Jake. Precious knowledge that you share.
