constraints will not finalize
Brooke_Bialas1
Member Posts: 5 ✭
I'm doing the Multi-part studios exercise. I went all the way through the clamp build and everything worked fine right up until I tried to change the dimensions then the part constraints on the 50mm pivot circle wouldn't change with the dimension changes. I went back and started the sketch drawing over several more times, but now I can't get the master sketch to finalize. I'm lost to what is going on.
Any help.
Any help.
Your sketch is not closed. See spline highlight. Line needs a coincident constraint to stay connected to arc. The horizontal constraint isn't doing anything useful.
The arms will continue to move unless you add something like a finalizing angle or something. Before adding the angle I was able to move things about such that the line pulls back and opens the sketch.
https://cad.onshape.com/documents/8bda7b8a22c0426a3ed20f6a/w/a103ecbcdb6047c20153607b/e/55231812773ea6d5e384e4d4
