Revolute mate and slider mate...
Hi,
I'm designing the tracks for a mobile robotic platform and I'd like to know how to remove the link between the revolute mate and the slider mates:
https://cad.onshape.com/documents/505734d8a6b86de5529f3f25/w/5828f0475dbf4b43a8c168da/e/5048137ac2ee1ee7b50f45b6
I explain the problem: when I manually rotate one sprocket of the track (revolute 1,2,3,4) the left yellow pieces move according to the slider mate (slider 1 and 2), but I want them to not move.
the direct link as you suggested is the same as the one I originally posted.
Yes, the problem occurs when I drag one of the two sprockets manually, even the rear sprocket that is fixed and cannot translate.
Is there a way to choose a mate, press the play button and see all the linked mates animating?
www.myzhar.com
What I want to do is adding the teeth to the rubber track to verify that the active sprocket is well designed.
I'd also like to simulate the chain in a realistic way seeing the teeth moving while the sprockets rotate.
www.myzhar.com
www.myzhar.com
Is this possible? I've always wanted to make an assembly in a CAD program where there's a chain with a sprocket at each end and the whole mechanism rotates just like it would in real life. I've never figured out how to do it though. Has anyone done this or have ideas how it might be done?
Not only that, it is a lot of mating which can really overload an assembly. What we need here is an assembly level path or chain mate similar to solidworks.
https://www.youtube.com/watch?v=etEZEP4Lkk0
I think that the main problem is that the path is not continuous
www.myzhar.com
