View small part larger
I am working with a part 4.013mm X 4.700mm that I would like it to be larger on the screen. How can I set it to be larger on the screen, but retain my specified dimensions?
    In 3D or 2D drawing?  In 3D, just zoom with mouse wheel. In 2D, right click the view and select view properties - you can change the scale there.
  • david_mach581david_mach581 Member Posts: 13
    edited February 2020
    I have used the mouse wheel, when sketching the same part, sometimes I can view it larger as I am drawing it. Thanks.
    @david_mach581
    It looks to me that those Part Studios have different units set.  You can check the units here:
    You can change the size of each of the default planes by clicking on one of them, and then dragging their corners:
    I understand both drawings are using different measurements, trying both measurement systems out. I have used the scroll wheel to enlarge the part, but
    every time I change the view, I have to enlarge it over again. Since most of my parts are small, is there a way once I set the part size,  I can view it say
    6-8 X and lock it so that it remains large?
    every time I change the view, I have to enlarge it over again. Since most of my parts are small, is there a way once I set the part size,  I view it say
    6-8 X and lock it so that when I change views it remains at 6-8 X?
    Thanks, I will try that.
    @david_mach581
    also - I like to hide planes ( 'p' key) and origin (eyeball).  Then zoom all will work to show only visible geometry.
    www.accuratepattern.com
  • alnisalnis Member, Developers Posts: 452 EDU
    You can also use the 'w' key to quickly drag a rectangle where you want the viewport to look. The 'f' key zooms out to see everything. By using those, you can quickly navigate a large model.
