Linked Sub Assemblies Are Not Updating To My Main Assembly After Adding New Feature
jordan_worthen
Member Posts: 1 ✭
I have a tube weldment fixture assembly with a few sub assemblies and I added a chamfer to all the parts in their respective sub assembly documents, now when I go back to make sure the chamfer I added was large enough I can not get it to update. I've tried everything I know how and have been stuck for quite some time. Thank you in advance!
Main Assy: https://cad.onshape.com/documents/ed73820650a57ef05a38b198/w/14eb1a4990dd1a61fd2681cc/e/1aabf803f31fe9d11a45c4f2
Sub Assy 1: https://cad.onshape.com/documents/4982e273218398de3621d59d/w/5dfd6115191855271464b1fb/e/53f8aabd145fe99aa93ced91
Sub Assy 2: https://cad.onshape.com/documents/5623b780a4f70188b5a6421a/w/b17b00bbba9f7abf1a972b9c/e/992e5dfe4c2ae8a53b356cf9
See second video here: https://forum.onshape.com/discussion/13009/improvements-to-onshape-february-17th-2020/p1
NeilCooke Opening a linked document from an Assembly will give you a version that apparently cannot be edited. What is the recommended workflow?
In this specific case I have moved the document and I can fix it by deleting the part in the assembly and reinsert but I would have expected things to work smoothly.
