How do you 'update' subassembly in main assembly within same document?
bruce_williams
Member, Developers Posts: 842 EDU
in General
I built partial sub-assemblies and inserted them into a main assembly. Now after adding parts, mates, etc. in the sub. the main is not getting all the mates. Am I missing an update step somewhere? Or other suggestion? I am attaching pictures of the sub and main.
www.accuratepattern.com
MBartlett21
Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
Can you try deleting and reinserting the subassembly?
5 -
Cris_Bowers
Member Posts: 281 PRO
Just suppress and unsuppress your group mate in the main assembly. Should fix it. It's one of those things that should really have attention called to it.4
that is it! thanks for quick answer.
P.S. After doing the suppress/unsuppress I got a diamond and something about negative impact on performance. What ???
As for your diamond and negative impact.. Do you have a screen shot of it? I can't remember ever seeing something like that
