self paced
neil_taylorneil_taylor Member Posts: 3
how do i complete a self paced course
  • KatieHuffmanKatieHuffman Member, Onshape Employees, Developers Posts: 194
    @neil_taylor to complete a self-paced course you must go through each lesson and page in the course. You will see green checkmarks and bubbles when you have completed a page in the course outline. It takes about 3 seconds on the page for it to turn green. Some courses have a feedback section at the end- those courses require the survey to be completed as well to complete the course. Feedback is great for us to deliver more and better material to you, however you can skip questions if you like. Hope that helps!
  • neil_taylorneil_taylor Member Posts: 3
    it is not allowing me to even stert the first course.no page available to draw the tutorial
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    Have you signed in, using the button on the right of this page (for example)? https://learn.onshape.com/learning-paths/introduction-to-cad
    You must be signed into Onshape to access the courses. The easiest way to be sure of this is to sign-in to Onshape and click the Learning Center button in the top right. This workflow automatically signs you in properly, using your Onshape account. Then you may navigate to the course and begin. Which course are you trying to access? The 4 intro courses and 12 fundamental courses are available to everyone- while some of the advanced courses are currently only available to certain types of Onshape subscriptions. If you are still having trouble, can you post a screen shot of what it looks like?
