Mirrored Assy, to Configure or not to Configure
brucebartlett
Member, OS Professional, Mentor, User Group Leader Posts: 2,148 PRO
While waiting for a solution auto-create mirrored assemblies, I normally just redo my opposite side with a new assembly but wondering if using a re-configuration of parts may be a better solution. What have others found?
@lougallo ?
PS: I did not notice it either 👀
Hopefully, when we get Mirrors for assemblies it will be able to handle release parts and assembly mirrors.
this works before changing to version
Once changed to a release the option to select Change configuration is gone
Yes, I did release both configurations and went into the parts studio of the released parts and they still switched around using the configuration so I see no reason this shouldn't work as works for versions.
