Revolute between two parts breaks other mates in the assembly
valentina_suppervalentina_supper Member Posts: 3 EDU
I am trying to revolute part 1 #3 and folding assembly so that when the right frame is moved laterally to the left frame, part 1 #3 and its opposing part move up and down the frame. Is ther ea way you can help me with this?
https://cad.onshape.com/documents/03ddba798af51c6a51162fcf/w/ceac57fbcd5b52399ec288ab/e/d832c23abf84ba94348ef325
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,932 image
    Change one revolute to a cylindrical - it is a tolerance stackup issue
  • valentina_suppervalentina_supper Member Posts: 3 EDU
    Thank you so much!!!! Life saver
