Tutorial 4, using Mac and Safari, Right clicking on in a Drawing.
william_makowskiwilliam_makowski Member Posts: 5
Hello,
Currently going through Tutorial 4. Never had this problem in the Part Studio, but when I go to right click in a drawing nothing happens. Any thoughts?
Thanks!
  • bobminerbobminer Moderator, Onshape Employees, Developers Posts: 50
    edited June 2017
    Hi William.  Do you have a document open and the active tab is a drawing?  If so, are you right clicking on the drawing tab, on the background of the drawing or somewhere else?  When I right click on the drawing / sheet background using Safari, I see a dropdown menu of commands "Sheet properties...", "Zoom to fit", "Zoom to sheet" and "Zoom to window".  When I right click on the drawing tab (at the bottom of the browser), I see a dropdown menu of different commands - "Open in new browser tab", "Rename...", etc.  Thanks.
    Bob Miner - Software Engineer / Dev Leader - Drawings - Onshape, Inc.
  • james_mongoldjames_mongold Member Posts: 1
    I have same problem... I know how to right click on a Mac (control-click) and when I do that in Exercise: Basic Drawing I don't get the anticipated/promised drop down menu. Running Mac, Safari, all the latest software:
    https://cad.onshape.com/documents/966f7504a4af54cccabdfb1c/w/d40b6fcf5dc239aedb653a57/e/3cf1807f96edebf505ef338f
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,848
    It works for me using the trackpad. Can you try that to see if it is related to the mouse for some reason?
  • oren_connelloren_connell Member Posts: 1 PRO
    I'm seeing the same issue on Mac, Firefox. Right click works in Parts or Assembly but not in drawings. I tested with an USB mouse and things work correctly.
  • kevin_daney054kevin_daney054 Member Posts: 10 EDU
    You can fix the problem by going to settings and make your mouse have Right Click.
    It worked for me.
  • bryce_bowmanbryce_bowman Member Posts: 1
    Right-click is not working in drawings. It works for me with part studios but there is no dropdown menu when I right-click anywhere in a drawings studio. How do I fix this?
