Loft Error - Can anyone tell me what is going on here?
scott_lipsham
Member Posts: 2 ✭
Hi all - Newbie here
Trying to do simple loft between top of milk jug and round base - should seem simple.
Kee
p getting this weird error when lofted
many thanks
Scott
Kee
many thanks
Scott
john_mcclary
Member, Developers Posts: 3,999 PRO
You may need to add some guide curves, or split the lower circle and match verticies5 -
John_P_Desilets
Onshape Employees, csevp Posts: 261
Hello @scott_lipsham
As @john_mcclary said, splitting the lower profile will do the trick.
This feature has six points.
Using the split command in the sketch toolbar, I split the second profile to match the same number of points as the first profile. Below is a top view of both sketches visible in the graphics area.
Second profile after being split
Here is the end result. Hope this helps!
https://cad.onshape.com/documents/9c284dd0668f6702b9dfe33b/w/814f2ff1d93d189b7281ba7b/e/7c680d1dbf38f1c20100af3b
7
