Haw to mate a bearing to flat part (extrusion) “A inch” from edges?
MS_021MS_021 Member Posts: 7 PRO
I need to fasten Sleeve Bearing with Two-Bolt Flanges to flat bracket.
What is the workflow?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,944 image
    Hello @MS_021 - can you post a screenshot of what you are trying to do? You may need to add a fasten mate relative to the edge of the flat part, then edit one of the mate connectors to add an offset of 1 inch (create the mate first, then expand the mate in the instance list and edit one of the mate connectors listed below it).
  • MS_021MS_021 Member Posts: 7 PRO
    Bearing should be mate to the right end of the extrusion.
    Thank you.
    Thank you
